1995 Ford Bronco firing order
1995 FORD BRONCO
EDOULDER
Engine Mechanical problem
1995 Ford Bronco V8 Four Wheel Drive Automatic
what is the firing order for a 95 ford bronco 5.8L v8
Aug 18, 2009 at 12:04 PM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_465.jpg
Aug 18, 2009 at 12:18 PM
EDOULDER
Does it matter where #1 starts. or as long as its in that order it will be fine.
Aug 18, 2009 at 3:22 PM
BMRFIXIT
  • 19,053 POSTS
For sure it does matter you have to have it as you see it unless the distributor was removed and turned
Aug 18, 2009 at 10:37 PM
