I recently changed the distributor on my bronco. It has a 5.8 engine it worked perfect for a while and one morning the engine would not turn over. I checked it and the timing was off. Now it runs but it stalls while the engine is running. It shuts off and wont turn over for a while then it runs. I also checked the ignition module and it works fine. I would appreciate it if you could help me on this matter. Thank you.
Nov 14, 2009 at 1:45 PM
