1995 Ford Bronco engine stalls
150,000 MILES • V8 • 4WD • AUTOMATIC
MANUELSALAS
I recently changed the distributor on my bronco. It has a 5.8 engine it worked perfect for a while and one morning the engine would not turn over. I checked it and the timing was off. Now it runs but it stalls while the engine is running. It shuts off and wont turn over for a while then it runs. I also checked the ignition module and it works fine. I would appreciate it if you could help me on this matter. Thank you.
Nov 14, 2009 at 1:45 PM
  • 110,251 POSTS
How far is the timing out? Did the distributor come loose? Are you able to get it in time?
Nov 14, 2009 at 3:45 PM
MANUELSALAS
I was able to set the timing, the problem now is that after it runs for a while it stalls and shuts off. The first time I replaced the distributor because It was not getting any power to the spark plugs. after I replaced it the first time the check engine light turned on but now after setting the timing it works fine and the check engine light doesnt turn on anymore. I also checked the control module and it works fine. Someone suggested that my Ignition coil might shut off after it heats up. Is that a possibility? thanks for the reply.
Nov 15, 2009 at 7:17 AM
