1995 Ford Bronco Bent frnt pasenger axial housing
142,000 MILES • V8 • 4WD • AUTOMATIC
TKD83
My mechanic informed me that the passenger side front axle housing was bent. The issue is that the axil does not seat all the way in the automatic hub and because of this when driving in two wheel drive and hitting a good size hole/bump the the front hub creates an extreem amount of noise. The way I get it to stop is by hitting another good bump or coming to a stop engaging the four wheel drive then disengaging it. I would like to correct this. I brought it to two shop's each of which stated a cost of $800-$1000 to repair and possible more. I am pretty handy and wonder if this is something that I could do on a weekend. What should the parts cost and what special tools would be required?
Thanks,
Mar 22, 2008 at 5:39 AM
FORDGUY217
Where do you live because I have a complete set of front i-beam's just laying in my shop there out of a 87 bronco that went to 2wd
May 19, 2008 at 6:30 PM
