1995 Ford Bronco 1995 Ford Bronco speedo,trans,and stalling
1995 FORD BRONCO
125,000 MILES • V8 • 4WD • AUTOMATIC
BOBBYMAC023
  • 5 POSTS
My ford bronco has gotten its tranmission replaced with a rebuilt one. Sometime after that the speedometer started wavering and then the bronco began to stall when coming to a stop sometimes.
This has happened before and it was a ground that was the problem. This time the ground is fine, the speed sensor has been replaced to no avail.
The Transmission also shifts at the wrong points and at 35mph switches back and forth and cant make up its mind.
A small thing i noticed is that after starting when i push the tripometer button the speedo dips and the readout of the mileage flashes and then i have to press it again to get the trip.
Any help would be greatly appreciated.
May 20, 2008 at 10:51 PM
MUSTANG87
  • 261 POSTS
you gotta take it back to whoever rebuilt it because it sounds like the trans is not working well and maybe its stalling at slowing to stop becausae its not down shifting to correct gear.also possibly because trans is not working good the speedometer cant read the speed correctly, or your cluster just happened to to go down at same time.
May 23, 2008 at 12:07 AM
BOBBYMAC023
  • 5 POSTS
Good thing i got a warranty on the transmission... will be taking it back to them and if its not fixed then i will get a new comp. Thanks for your help. I while post an update
May 29, 2008 at 8:12 PM
