1995 Ford Bronco 1995 Ford Bronco 4x4 4 low not working
151,000 MILES • V8 • 4WD • AUTOMATIC
BTKCAMDEN
I just installed manual hubs in my 1995 Ford Bronco and my 4 low isn't working but the 4 high is. When I push the 4 low button, it will not light up, engage, or make any kind of noises. What could the problem be? Thanks.
Apr 26, 2009 at 5:01 PM
  • 110,248 POSTS
Hi:
You need to check to see if you are getting power to the 4wd actuator on the transfer case. If you are, chances are the actuator is bad. If there is no power, start with the switch.
Jun 4, 2009 at 4:27 PM
