1995 ford bronco
1995 FORD BRONCO
BOBBYMAC023
  • 5 POSTS
Hi, I have a 1995 Ford bronco with the 5.0l v8. It has been running pretty well until recently. I put in some fuel injector cleaner and since then the speedometer has been jumping at every speed, but worse the faster you go. When stopping the engine cuts out once in a while. It cuts out more often the harder you stop. The transmission is not shifting at the right points and it gets confused. For instance on a high way while cruising sometimes the transmission shifts and then shifts right back repeatedly and it feels like its gonna get ripped off. Then i change the throttle and it works fine. This all goes in and out though for instance as im driving sometimes everything goes back to normal or sometimes it goes from normal to everything i described. Thanks for any help.
May 12, 2007 at 11:07 AM
BOBBYMAC023
  • 5 POSTS
thanks a lot will do
May 12, 2007 at 6:13 PM
BOBBYMAC023
  • 5 POSTS
alright i replaced the speed sensor and that didnt help.... then i found a broken ground wire.... redid that and its completely fixed.... thanx for the help thou
May 16, 2007 at 11:46 PM
