1995 Bronco Heaterbox
VTL241
I am trying to replace my 1995 Bronco Heaterbox (with A/C). This Fullsize Bronco has 130,000 miles on it and it is a 5.0L Automatic Engine.
I got another heaterbox at the junkyard which was from a 1989 Bronco and they told me it should fit. I need a professional opinion if the 1989 Heaterbox can work with the 1995 Bronco?
Can you please help?
Thanks,
Alex
Sep 10, 2007 at 6:40 AM
MERLIN2021
  • 17,250 POSTS
I will say this I doubt it, and why would you do all the work required to replace the a/c plenum/ heater core and then use a JUNK part? What will you do even if it does fit, then leaks after 10 or 12 hours of work?
Sep 10, 2007 at 6:46 AM
