1994 Ford Bronco Will not shift into gear
160,000 MILES • V8 • 4WD • MANUAL
BLEON111
While driving, I can shift into 1st and 2nd and 5th gear. It will not shift into 2nd or 3rd. When shifting into those two positions it feels as though it is "freewheeling" and nothing is engaging. I can skip right over them and 5th does engage. Reverse still engages as well. Thank you for your assistance.
Sep 10, 2009 at 12:30 PM
BIGJIM79
  • 239 POSTS
It could be that the shifting forks are bent or the fork is completely broken. TRy shifting with engine off and see if you can hear the gears engageing.
Nov 25, 2009 at 12:12 PM
