1994 Ford Bronco Looses fuel Pressure
160,000 MILES • V8 • 4WD • AUTOMATIC
MATT MOBLEY
Replaced fuel pump, x2 replaced fuel filter x 2, replaced pressure regulator, replaced computer, and it continues to loose fuel pressure to the point of stalling out, after turing ignition completly off the pressure returns to normal and then shortly there after same thing happens again. Along with other symptoms relays tend to get warm sometimes hot.
Short of taking it to a Ford Dealer, not sure what eles to do
May 25, 2010 at 10:22 AM
  • 75,988 POSTS
The injectors could be leaking dropping the pressure
May 25, 2010 at 11:08 AM
