1994 Ford Bronco instrument cluster
1994 FORD BRONCO
FROSTBRONCO
Electrical problem
1994 Ford Bronco V8 Four Wheel Drive Automatic
i have a 94 bronco 5.8l. i replaced the psom because the tranny was shifting hard. now the airbag and check engine light are on. i checked the conversion constant and it was correct for the tires that are on the bronco(31x10.5) the speedometer and all the other gauges work as they should. what could be my problem
Oct 8, 2010 at 11:54 AM
  • 110,244 POSTS
Have you had the computer scanned for trouble codes? Also, as far as the air bag, it could be a sensor. Have the computer scanned to see what the trouble codes are that are stored. Let me know what you find, and most parts stores will do it for free.
Oct 15, 2010 at 3:17 PM
