1994 Ford Bronco how to clean carburater
LAYTON C
  • 1994 FORD BRONCO
Engine Mechanical problem
1994 Ford Bronco V8 Two Wheel Drive Automatic
116,000
Thursday, July 30th, 2009 AT 5:59 PM
  • 31,937 POSTS
HI there,
you will need to remove and dismantle the carby, wash and clean internal passages with carby clean, if corroded you can have them soaked in a mild acid cleaning bath re build with a full overhaul kit, but be carefully one mistake and you will be pulling it apart again, if you have never done one, best left to a mechanic.
Mark (mhpautos)
Thursday, July 30th, 2009 AT 6:46 PM
