1994 Ford Bronco Freeze Plugs
1994 FORD BRONCO
LILY FOSNIGHT
Engine Cooling problem
1994 Ford Bronco V8 Automatic
How do I replace the freeze plugs, and how many are there? Do you have a step by step guideline I could follow?
Thanks, Lily
Dec 26, 2008 at 10:32 AM
BLACKOP555
  • 10,386 POSTS
should be about 10.
and by no means will you be able to replace them all with the engine or all of its components in the vehicle.
to take them out you have to take a punch and hit the side and turn them sideways in the bore to pull them out with a pair of pliers. or you have to drill a hole in them and pull them out witha sheet metal screw and a slidehammer
once you get them post back and well discuss putting them in.
Dec 30, 2008 at 1:28 AM
