1994 Ford Bronco Error 212
1994 FORD BRONCO
100,000 MILES • V8 • 4WD • AUTOMATIC
BOBBY789
I had a friend of mine run a test on my bronco. The machine showed code 212. The truck runs good sometimes, then other times the RPM drop when im at a stop. then the go back up. I replaced the fuel filter plugs and wires. It's still doing the same thing. I need HELP..
Nov 22, 2009 at 3:06 PM
BIGJIM79
  • 239 POSTS
it should mean that it doesn't have any codes available. It sounds like you may have a vacum leak some where for the rpm's to drop. You can use some water and soap on the hose as it will bubbe when you have a leak.
Nov 25, 2009 at 11:37 AM
