1994 Ford Bronco Engine Oil Pump
70,000 MILES • V8 • 4WD • AUTOMATIC
ALABAMARED
After engine warms up the oil pressure falls. If engine rpms is increased oil pressure rises. Need to get to the oil pump and check out or replace. What do I have to do to access the oil pump and repair or replace?
Oct 26, 2010 at 5:14 PM
  • 75,988 POSTS
Hi Alabamared,Welcome to 2carpros and TY for the donation.
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch. If abnormal could mean oil pump and/or engine bearing.
Oct 26, 2010 at 9:07 PM
