1994 Ford Bronco Battery Draining
309,000 MILES • V8 • 4WD • AUTOMATIC
TROLLUP
My BAttery is putting out 658 CCA,The starter was replaced 2 months ago, replaced the Alternator today.Charging system is working perfect
What is causing my battery to drain in a matter of seconds? I can hear a buzzing sound coming from the firewall for about 10 seconds after I turn off the engine.
Jul 19, 2010 at 5:16 PM
  • 75,988 POSTS
Put an ammeter or test lite in between the negative cable and the negative battery post if the lite is on or a draw is present-start removing fuses one ar time till the lite turns off this is where the short circuit is-
To drain that fast check the starter and the relay
Jul 19, 2010 at 5:31 PM
