1994 Ford Bronco abs warning light
1994 FORD BRONCO
JORDAN LACEY
Brakes problem
1994 Ford Bronco V8 Four Wheel Drive Automatic
I just replaced the brake pads on this 94 bronco and now the abs light is on. I don't know what could be causing this as it was not on before.
Sep 26, 2009 at 9:50 AM
  • 110,244 POSTS
Check the sensors on the rear of the wheels. You may have disconnected a sensor or damaged wiring. Also, make sure the brake fluid is full. If everything looks good, have the computer scanned at a nationally recognized parts store. Most will do it for free and it will identify where the problem is coming from.
Oct 23, 2009 at 5:07 AM
