1994 Ford Bronco 1994 bronco fuel pump
WESMESS5
1994 Ford Bronco
I thoulg the whole fuel pump need to be replaced however it look like the Hanger assembly is the only thing broken ( the circle disk with wires above the sending unit) IS that what it is called? Can only this one part be replaced? Does it require special tools? Recomendations?
Sep 6, 2010 at 11:34 AM
WRENCHTECH
  • 20,760 POSTS
That's usually called the fuel pump module. Some manufacturers sell it separately and some sell it with a pump. You'll have to inquire at the dealer.
Sep 6, 2010 at 12:11 PM
