1993 Ford Bronco water pump
140,000 MILES • V8 • 4WD • AUTOMATIC
FROADER2
the chiltons says i need to remove the engine plugs along with the radiator plug to drain the system prior to changing the water pump. i do not know where the engine plugs are. the book does not provide a picture. can you show me where they or it is? is there any other usefull tips a newby like me could find helpful before i tackle this repair?
thank you,
elaina
Jan 25, 2009 at 1:59 AM
DOCFIXIT
  • 18,828 POSTS
Just drain radiator remove hoses and pump don't be concerned about block plugs. Do you have that humongeous nut on fan?
Jan 26, 2009 at 5:27 AM
FROADER2
no there were 4 bots for the fan. it went well until.. the water pump had been leaking for a while so there was alot of rust. the bolts for the pump were siezed or rusted solid into the motor. after much labor, we were down to one last stubborn one and had to leave it in its final resting place. but the new pump is on and we are good for now. thank you for your response.
Jan 31, 2009 at 1:32 AM
