1993 Ford Bronco TPS sensor
136,000 MILES • V8 • 4WD • AUTOMATIC
RONF27
My check engine light is on. I received a diagnostic and was told to change the erg valve, evp sensor, and the tps sensor. I changed the first two, but can't figure out how to get the Tps sensor off. How do you unscrew it or remove it?
Jun 7, 2008 at 12:53 PM
BLACKOP555
  • 10,386 POSTS
i wouldnt suggest chaning it, as if its installed improperly the vehicle will run horribly. is it TBI injected?
some were.
if so it cannot be replaced.
Jun 7, 2008 at 2:32 PM
