1993 Ford Bronco stalling out
DMCGHAN0523
  • 1993 FORD BRONCO
  • V8
  • 4WD
  • 188,000 MILES
For the last week when I stop and then accelerate the rpm's drop really low and almost stall my truck then it picks up and while i'm pressing the gas its fine. Today I stopped and accelerated and it completely bogged out and stalled my truck. I couldnt get it started until I pressed the gas pedal to the floor. What could the problem be?
Wednesday, October 15th, 2008 AT 11:41 PM
Do you have a check engine light and when was the last tune-up?
What you need to do is check the fuel pressure make sure its within specs-if okay
Start checking components that will affect idle and acceleration-such as the idle air control valve/motor, throttle position sensor, mass air flow sensor, to include the PCV and the EGR valves.
Thursday, October 16th, 2008 AT 3:09 AM
