1993 Ford Bronco Speedometer stopped working
1993 FORD BRONCO
140,000 MILES • V8 • 4WD • AUTOMATIC
I HATE DON
My speedo was shaking and acting like a cable was fraid causing the speedo needle to jump. Now the speedo does not work at all and the truck is not shifting properly. But after looking I have no cable at the back of the speedometer. where do I need to begin looking to fix this problem ? Also my ABS lite has been coming on and off, now on more than off !
Is it electrical or mechanical and where do I need to look for repair ? This is on a Eddie Baur Edition.
Can you help me or give me direction ?
Dec 28, 2009 at 12:35 PM
BLUELIGHTNIN6
  • 16,542 POSTS
hello and thanks for the donation!
does your odometer operate good?
these symptoms all point to a faulty speed sensor, since this is what is used to operate the speedometer and also sends signals for use of the transmission. the speed sensor is located on the rear axle.
Dec 28, 2009 at 5:34 PM
I HATE DON
Thanks for the response, at least now I have a direction to look towards. The odometer is digital and stopped working when the speedometer did, the speedometer is a needle type. Is the speed sensor on the rear axle a job I can do myself ? Where on the axle will I find it ? Will I need to re-calibrate the speedometer when I change out the sensor ? Could this be causing the intermittant on and off of the ABS light ?
Dec 29, 2009 at 12:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1357.jpg
Dec 29, 2009 at 6:56 AM
