1993 Ford Bronco problems starting
170,000 MILES • V8 • 4WD • AUTOMATIC
NAPPY2DOPE
I have a 93 Bronco, in the past six months it has started hard, I just thought it was a weakening battery. Recently I tried to start it and it sounded strange, a kind of wheezing sound, and a smell of electric burn. The next time i tried to start it, It made the same noise, started, even ran well for a moment, then the lights died, and it sputtered to a halt. The engine stopped but the noise got worse, and it didn't stop when I took the key out, I had to disconnected the battery. Now when I hook the battery up, it makes the noise, I have no idea what it is, please help.
Jul 20, 2010 at 7:26 PM
  • 75,988 POSTS
1st step here is to test the ignition switch if it continues to run when the key is out, shouldn't continue to run w/o the key
Jul 20, 2010 at 8:31 PM
