1993 Ford Bronco leaking colant
1993 FORD BRONCO
BALDRN03
Engine Cooling problem
1993 Ford Bronco V8 Four Wheel Drive Automatic
my truck is losing coolant under truck it streams out under a bracket not a hose
May 26, 2008 at 2:45 AM
MERLIN2021
  • 17,250 POSTS
Best way to track down a leak is with a pressure tester, but if it's from the bottom of the engine, inspect the freeze plugs, these are round metal discs that over time corrode and leak. Replacement trypes incled an easy to use rubber expanding plug, remove all of the old one and install the new one, I do prefer using the metal one, the rubber ones sometimes blow out! Your choice tho...
May 26, 2008 at 3:10 AM
