1993 Ford Bronco instument cluster
1993 FORD BRONCO
MCHLAHRP
Interior problem
1993 Ford Bronco V8 Four Wheel Drive Automatic 160k miles
hello i have a 93 ford bronco i have a rattling in my dash i know its my speedometer my question is how do i take the cluster out so that i can fix it my meter works its just noisey but my feul gauge does not work could this be fixed while removing the cluster?
Nov 25, 2008 at 9:13 AM
DAVE H
  • 13,384 POSTS
FUEL LEVEL GAUGE
Turn ignition off. Unplug connector from fuel level sending unit, located at fuel tank. Connect one terminal of Gauge Tester (021-00055) to Yellow/White wire at harness connector. Connect other wire to Black/Yellow wire at connector.
Set tester to 22 OHMS position. Turn ignition on. Wait 60 seconds. Observe fuel gauge. If gauge indicates "E", go to step 5). If gauge does not indicate "E", turn ignition switch off, then turn it back on. Tap instrument panel. Wait one minute. If gauge goes to "E", check for intermittent B+ connection at cluster connector, or for damaged printed circuit. Repair as necessary and repeat test.
If after repeating test, gauge does not indicate "E", turn ignition off. Remove instrument cluster. See INSTRUMENT CLUSTER under REMOVAL & INSTALLATION. Inspect printed circuit for damage. Remove slosh module, located on back of cluster. Connect jumper wire from gauge tester to fuel gauge connector SIG terminal (Yellow/White wire).
Turn ignition on. Observe gauge. If gauge does not indicate "E", replace gauge. If gauge indicates "E", replace slosh module.
If gauge indicates "E" in step 2), turn ignition off. Set gauge tester to 145 OHMS position. Turn ignition on, wait 60 seconds, and observe fuel gauge. If gauge indicates "F", check sender circuit wiring for shorts or opens. If gauge does not indicate "F", turn ignition off. Remove instrument cluster. See INSTRUMENT CLUSTER under REMOVAL & INSTALLATION.
Inspect printed circuit to verify loop connecting fuel sender input to fuel gauge is cut. If loop is not cut, cut printed circuit at loop.
Remove slosh module from rear of cluster, and connect jumper wire from gauge tester to fuel gauge connector SIG terminal (Yellow/White wire). Reconnect cluster wiring. Recheck gauge.
If fuel gauge indicates "F", replace slosh module. If gauge does not indicate "F", replace gauge.
Measure sending unit resistance. With float arm in empty position, resistance should be 15 ohms. With float arm in full position, resistance should be 160 ohms. If resistance is not as specified, replace sending unit. Retest system.
Removal & Installation (Bronco, Pickup & Van)
Disconnect negative battery cable. On models with tilt column, position steering wheel in full down position. On models with column shift, set parking brake and move shift lever to lowest position. On all models, unsnap right and left moldings.
Remove headlight knob. Use a hooked tool to release knob lock spring. Remove 2 exposed screws under right and left moldings. Unsnap retaining clips by pulling cluster trim panel rearward. On A/T models, remove loop on shift indicator cable from column retainer pin.
On all models, remove thumbwheel bracket screw. Detach bracket from steering column. Remove cluster finish panel. Remove 4 cluster screws. Pull cluster away from panel. Unplug connectors. To install, reverse removal procedure.
Nov 25, 2008 at 9:27 AM
