1993 Ford Bronco harmonic balancer
BOBBYRMR
Engine Mechanical problem
1993 Ford Bronco V8 Four Wheel Drive Automatic
how do i keep engine from turning to take center bolt out, and wich direction to loosen bolt
Jan 30, 2010 at 5:28 AM
  • 75,988 POSTS
You can use an impact on it or a a breaker bar and brace it underneath properly and use the starter to break it open-the turn is C/C
Jan 30, 2010 at 8:03 AM
