1993 Ford Bronco exhaust overheating
1993 FORD BRONCO
150,000 MILES • V8 • 4WD • AUTOMATIC
DEADMAN63
I recently got a 1993 bronco running after it had blown two freeze plugs and sat for about a year,I replaced the spark plugs and distributor cap and rotor. now when I start it it has truble ideling and stalls when i put it in gear,also the exhaust pipe between the two cats glows bright red.does this mean the rear cat is clogged? or is it something else?
May 4, 2009 at 3:33 PM
Disconnect the rear Cat and see what happens and also check the oxygen sensor
May 4, 2009 at 3:44 PM
