1993 Ford Bronco engine starting problem
195,000 MILES • V8 • 4WD • AUTOMATIC
HUNTGUNNER16
I have been driving a 93 ford bronco with a 5.8 liter windsor for years but in the past year it has become harder and harder to start when its warm. It starts rather good when cold (does crank over twice during the turn of key before starting) when engine is at operating temperature and is not started right back up, after about 30 min of sittin with motor off it refuses to start. It just cranks with no attempt of starting for entire first crank then it hesitates but will usually start second crank any help would be great!!!!! thanks
Nov 17, 2008 at 4:24 AM
  • 110,248 POSTS
Hi:
Have you tried a fuel injector cleaner? Also, you may want to have the fuel pressure checked. The fuel pump could be getting tired of loosing its prim.
Let me know if this helps.
Nov 25, 2008 at 3:07 PM
