1993 Ford Bronco 4x4 switch
185,000 MILES • V8 • 4WD • AUTOMATIC
QUICKERR
My 93 bronco will not engage the four wheel drive. When I press the button to engage there is a clicking sound from under the glove box and it will not engage. I have tried a different switch out of an explorer and it does the same thing ( I realize that explorers and broncos aren't the same the switches have a strong resemblance though). Is the switch that particular as far as function? What else could be the problem?
Jul 2, 2010 at 8:07 AM
RICHZOMBIE
  • 173 POSTS
An occasional problem on this vehicle is failure of the 4WD Shift Motor.The cost to repair the 4WD Shift Motor is estimated at $250.00 for parts and $65.00 for labor. You may want to get that switch checked.
Jul 2, 2010 at 8:57 AM
