1993 Ford Bronco 4WD Relay
175,000 MILES • V8 • 4WD • AUTOMATIC
TOOLMANCURTIS
I just recently bought my Bronco and the 4WD is not Kicking in when I press the automatic switch. The indicator light is not coming on in the switch. I tried changing out the switch and its doing the same thing. When you press the button you can hear a clicking under my dash around the glove box. My guess is its possible a relay on the tranfer case. Any suggestions or links to a schematic so I know what I am looking for would be greatly appreciated.
Thanks,
Oct 18, 2010 at 8:15 AM
  • 110,248 POSTS
You are hearing the relay which tells me the switch is good and there is power to the relay. I need you to check to see if there is power to the actuator on the transfer case.
Let me know what you find.
Oct 21, 2010 at 12:11 AM
