1993 Ford Bronco 1993 Bronco No Start Hot
TMBKB
  • 13 POSTS
Engine Performance problem
1993 Ford Bronco V8 Four Wheel Drive Automatic
Anybody have this problem - cant find fix.
5.8L engine starts just fine; runs just fine; After driving for a period of time and engine gets hot and you turn it off for 15min or so, engine will not start until cools down about 30min.
Engine is not overheating; gauge is running mid-normal; when trying to start seems to be fuel starved; tries to fire the 1st few times; then appears to detonate; then just spins with no firing.
After 30 min cool down, engine starts just fine, sputters a few times, then runs just fine.
Looking for a cause: what would make the engine do this?????
thanks
Sep 17, 2009 at 4:29 AM
DOCFIXIT
  • 18,828 POSTS
Hi
When it quits pull plug wire hold 1/4 in from block crank fire.If yes spray some carb cleaner into air intake crank fires?
Let me know
Thanks for donate
Sep 17, 2009 at 4:40 AM
TMBKB
  • 13 POSTS
Seems to me that is just another symptom. Something is causing engine to either not spark or fuel.........
doesnt do this except when it is hot and u turn it off and restart later.
Sep 17, 2009 at 4:46 AM
