1993 Ford Bronco
149 MILES • V8 • 4WD • AUTOMATIC
MARKGEROW
ok i have a 1993 ford bronco xlt i just had injectors done and all the tune up parst have been done along with a after market air intake kit when i start it up in the morring or when the motor is cold i have to keep my foot on the gas for a few minits till it can idel its self when i started it today it idels fine with out my help it did that for about a minit and then just died it took about 10 or 20 minits to start back up i was told to check the battery and the battery cables when i hade it at the shop it had a compreshon test done and it passed with flying colors it was 110-115 all around its in time and every thing when it stalls out and i try to start it up agen its like its not geting gas but when its warmed up it will run fine
Dec 12, 2009 at 10:16 AM
  • 75,988 POSTS
For a start check and test the engine coolant temperature sensor and clean out the idle air control valve and see what happens.
Dec 12, 2009 at 10:24 AM
