1992 Ford Bronco won't start
150,000 MILES • V8 • 4WD • AUTOMATIC
JUSTA_LIL.DEMON
It's a Ford Bronco '92 4x4 automatic, been having problems starting it so the selenoid on the side was replaced, then the truck would start most of the time. However from time to time it would just make a clicking noise again and not start, but eventually would if ya let it sit for a while, but 2 weeks ago it started and when it was shut off to run in somewhere then come back out to start it again, it wouldn't. Now it has never started since and i bought a new starter which has the second selenoid attached to it and still nothing. Checked the battery, battery cables, the wirering connecting to the battery from the starter and so on...still nothing! Please help us we are going out of our minds over this truck and we really need this viehichle to run again!.....signed, desperate & baffled
Jul 13, 2008 at 9:17 AM
MUSTANG87
  • 261 POSTS
hello kinda late for answere but ill try.try changing the ignition starter switch.it goes on the steering column under dash .possibly thats your problem.go here and see what it looks like so you will find it easier www.kragen.com good luck
Jul 16, 2008 at 12:26 PM
