1992 Ford Bronco will not start fuel?
GLOCKNUTDOTCOM
Electrical problem
1992 Ford Bronco V8 Four Wheel Drive Automatic
When the truck got hot it died and would not restart untill later that night. The next day it ran fine drove all over then when we stopped and turned it off it would not start and has not started since. We replaced the ignition control and it started for a moment useing starting fluid. It has fuel up to the fuel injectors and it has spark at the plugs. I am thinking the injectors are not firing but not sure how to check them or what controls them.
Aug 8, 2009 at 8:34 AM
  • 75,988 POSTS
Check the fuel pressure with a gauge and also listen to the injectos if its clicking or use a noid lite.
Aug 8, 2009 at 9:18 AM
