1992 Ford Bronco Water submerged
197,000 MILES • V8 • 4WD • AUTOMATIC
GRASSFIRE1
I submerged my Bronco up to the floor boards last night. I was stuck for about 2 1/2hrs. It ran for the 1st 1 1/2hrs in the water then it quit working, it wont even turn over. Today it still wont turn over. I had it towed home.
Where do I start on fixing this issue?
Feb 25, 2009 at 9:38 AM
BILLYMAC
  • 2,204 POSTS
first remove the spark plugs try and crank engine if cranks get all water out of the cyl. change oil.if it will crank and not run drain water from exhaust
Feb 28, 2009 at 11:59 AM
