1992 Ford Bronco no power
156,000 MILES • V8 • 4WD • AUTOMATIC
HARLEY21
my 92 full size bronco won't run it started on long drives about 60 mi or so would just die and would'nt start for about 40 min or so now it will start but as soon as you touch the gas it dies but if you pump the gas it will run up to 5000 rpms but will then start popping out the throttle body air intake but will idle fine also if i block one side of the intake it will run up to that rpm fine have replaced the tp sensor egr sensor air bypass fuel filter gas tank had a leak thats when it started and also replaced the ecm and fuel pressure reg
Jan 12, 2008 at 1:06 PM
CFBRONCO19
  • 15 POSTS
CHECK THE TIMING ON THE MOTOR. IF IT'S 302 5.0L, THE TIMING SHOULD BE AT 10 DEGREES BEFORE TOP DEAD CENTER. THAT POPPING SYMPTOM YOUR GETTING THROUGH THE INTAKE IS LEAN CONDITION, THE TIMING MIGHT BE OFF-SET. IT COULD BE A SLOPPY TIMING CHAIN AS WELL. CHECK THE TIMING BEFORE ANYTHING
Feb 15, 2008 at 11:35 AM
