my 92 full size bronco won't run it started on long drives about 60 mi or so would just die and would'nt start for about 40 min or so now it will start but as soon as you touch the gas it dies but if you pump the gas it will run up to 5000 rpms but will then start popping out the throttle body air intake but will idle fine also if i block one side of the intake it will run up to that rpm fine have replaced the tp sensor egr sensor air bypass fuel filter gas tank had a leak thats when it started and also replaced the ecm and fuel pressure reg
Jan 12, 2008 at 1:06 PM
