1992 Ford Bronco missing
BILL BURDETTE
Engine Performance problem
1992 Ford Bronco V8 Four Wheel Drive Automatic
Why does my 1992 Bronco miss while driving
Nov 9, 2010 at 10:08 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Manifold absolute pressure sensor
Nov 9, 2010 at 10:21 AM
