Engine Performance problem
1992 Ford Bronco 6 cyl Four Wheel Drive Manual
i replaced the water pump now it idles at around 3000 rpm,also is there anyway around the switch on the clutch that requires the clutch pedal being depressed before starting?
Oct 8, 2008 at 1:50 PM
