1992 Ford Bronco hot and cold
198,000 MILES • V8 • 4WD • AUTOMATIC
JPUGGIONI
when it is cold it will get 1st 2nd 3rd and overdrive including reverse.once it is warmed up i only get forward which starts in 3rd gear.could this be the filter and fluid need to be replaced because of not enough pressure ? thank you for your time sincerely joseph puggioni
Jan 1, 2008 at 9:10 AM
MIKE H R
  • 3,094 POSTS
how does the fluid look? does it look brownish and does it have a burnt smell. , first try having the fluid and filter changed some places can even flush the system,.
Jan 8, 2008 at 2:17 AM
