1992 Ford Bronco fuel system problems
152,000 MILES • V8 • 4WD • AUTOMATIC
JCOLLINS0001
Takes me a while to start engine after sitting overnight. Usually at first it has really realy low power.
When I first turn the ignition the fuel pump is very loud. Yesterday I was driving down road and it just cut off, took me a while to get started, and when it does the low power again. when the fuel guage reads about a 1/4 it seems to be okay until I fill the tank again(33 gal. tank) Sometimes it will start right up and run for a few seconds and shutoff like it is out of fuel or something. Could this be that the fuel pump is going bad or something else ?
Thanks,
JEff
Nov 14, 2009 at 8:47 PM
BIGJIM79
  • 239 POSTS
I WOULD SAY FUEL FILTER FIRST THEN THE FUEL PRESSURE REGULATOR. tHEN FUEL PUMP.
Dec 1, 2009 at 1:31 PM
