1992 Ford Bronco front brake line
94,000 MILES • V8 • 4WD • AUTOMATIC
MEMPHIS46208
I am having trouble getting the front brake lines properly seated to screw in this is the line that runs side to side and the fitting is not very visable
Feb 4, 2009 at 6:03 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:5891055138="memphis46208"]Brakes problem
1992 Ford Bronco V8 Four Wheel Drive Automatic 94000 miles
I am having trouble getting the front brake lines properly seated to screw in this is the line that runs side to side and the fitting is not very visable[/quote:5891055138]
When you got the new lines did you take the old ones off and take them with you to match them up?
Ford has a nasty habit of one end being Standard and the other being Metric. So that may be your problem if you are using standard lines.
Feb 4, 2009 at 6:09 AM
