1992 Ford Bronco auto trans
1992 FORD BRONCO
JOHN BISPHAM
Transmission problem
1992 Ford Bronco V8 Four Wheel Drive Automatic
how do i flush out trans
Nov 2, 2009 at 11:10 PM
BIGJIM79
  • 239 POSTS
I have used kerosine since it is oil based and won't damage the cluthes inside. It is best to take to a shop that has a flush pump. The way I did it was drain fluid and replace with kero. and run for 3min. Drain again and repeat. Then drain and let sit for 30 min. draining. replace with new fluid and filter and drive. I hope this helps.
Nov 25, 2009 at 11:51 AM
