1992 Ford Bronco
SAVATTERE
Engine Mechanical problem
1992 Ford Bronco V8 Four Wheel Drive Automatic
no power no spark has gas has elctrie lights.radio,blinkers,ect
Jul 18, 2010 at 9:41 PM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 18, 2010 at 9:46 PM
