1991 ford bronco with 5.0 v8 and 168,000 miles
JERAMIE RENO
I recently bought this bronco so I have no knowledge of its history. The bronco will start and idle fine. And when I give it some gas in park or nuetral the engine will rev up to at least 4000 RPMs. And when I put it in drive it will move, but when I give it the gas the motor doesn't idle up. Any advice or info would be most grateful
Dec 14, 2006 at 9:46 AM
CUCAMONGAN
  • 7 POSTS
I would suspect the TPS (throttle Position Sensor) or the IAC (Idle Air Control) to be your culprit. You can go to Fullsizebronco.com and search there and they will tell you everything you need to know.
Hope this helps
Feb 18, 2007 at 6:03 AM
