1995 Ford Bronco High Idle
230,200 MILES • V8 • 4WD • AUTOMATIC
BNSF4999
Hello-
I have a '95 Bronco with fairly high mileage. Beginning yesterday when starting, the engine immediately revs up way above high idle. I asked and was told it was a leak in the intake manifold gasket. Does it sound like this is correct? I've never had any problems, but it runs at such a high rpm now, as soon as I let off the brake the truck just takes off and has no problem holding 30mph without holding the accelerator down! I've had all the fluids changed in the last 6 months and as said, it normally runs great.
Thanks!
Oct 26, 2008 at 3:49 AM
MERLIN2021
  • 17,250 POSTS
Check the throttle plate and cable, sounds like one is sticking, with 230,000 a good cleaning of the TBI is in order, use only throttle body cleaner, with the motor off. Disconnect the cable and see if the idle returns to normal.
https://images.2carpros.com/forum/automotive_pictures/62217_CRC_Throttle_Body_9.jpg
Oct 26, 2008 at 3:57 AM
