1991 Ford Bronco wipers
175,000 MILES • 6 CYL • 4WD • MANUAL
HOMER618
The wipers began having problems about 18 months ago. First, the intermittant function stopped. Next, when the wipers were turned off, they stopped immediately, not returning to the rset position. Now, the intermittant does not work at all and neitther does the slow speed.
Apr 22, 2010 at 1:50 AM
  • 110,248 POSTS
Hi:
If they still work on high, then the motor is good and has a good ground. I suggest checking the switch to see if that is where the problem is coming from. THat would be my first guess based on your description.
LEt me know.
Apr 24, 2010 at 1:56 PM
