1991 Ford Bronco Turned Off When Driving
1991 FORD BRONCO
250,000 MILES • V8 • 4WD • AUTOMATIC
CGDOIRON
Recently driving this Bronco when the engine suddenly turned off. I smelled distinct scent of electric/plastic burning. Smell was strongest in the driver seat. No noticible smells under the hood. Now it will crank but will not turn on. Any ideas?
Feb 23, 2010 at 3:33 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Possible ignition switch burned remove column shrouding and see if it looks burnt and melted.
Hope this helps
Thanks for donate
Feb 24, 2010 at 1:32 AM
CGDOIRON
So it turns out that it wasn't the ignition switch. Old one seemed fine but still replaced it just in case.
I did notice that the fuel pump does not kick in when the key is turned to the on position. Normally, I hear a high pitched whine from the back of the Bronco when I turn the key and before the car starts. That is not happening now even though the battery is fine and the engine does crank.
Any suggestions? Keep in mind that I am absolutely certain that the smell was electrical and inside the car when the Bronco turned off.
Mar 3, 2010 at 7:37 AM
DOCFIXIT
  • 18,828 POSTS
Check for power at Ful pump relay also check fuse links at starter trelay see if one is burnt
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_375.jpg
Mar 4, 2010 at 7:49 AM
