got gas n battery charged.turn key tries to turn over but doesnt
Jun 4, 2009 at 2:00 AM
✓Experienced Mechanic
Have you checked fuel pump pressure and for spark?
Jun 4, 2009 at 2:40 PM
KENF
MEMBER
got fuel pump pressure but no spark off plug from ignition coil new ignition coil
Jun 4, 2009 at 2:46 PM
Are you getting power to the coil?
Jun 4, 2009 at 4:21 PM
KENF
MEMBER
the wires into the coil has power maybe brain box
Jun 4, 2009 at 11:53 PM
If you have power to the coil, I have to agree with you if you are refering to the square brain. Did the problem happen all at once or was it running then shut down for no apparent reason and restart at a later time?
Jun 5, 2009 at 4:11 AM
KENF
MEMBER
it made a noise while i was starting it and never started since.i even changed ignition switch
Jun 11, 2009 at 4:16 AM
