1991 Ford Bronco Shake, rattle, and roll...
102,000 MILES • V8 • 4WD • AUTOMATIC
LORENZOALVISE
About two weeks ago I noticed a slight vibration coming from what I thought was the transmission. Then about a week ago it became much worse. Here lately I've heard "clunking" sounds from the vicinity of the rear end. Also two dummy lights came on and stay on continuously...the "brake" and the "rear antilock". What is it?!?
May 18, 2009 at 2:49 PM
  • 110,248 POSTS
I would start by checking the rear brakes and making sure there isn't too much play in the axle itself. There could be a bearing in the differential or the axle that is causing the problem. Also, make sure the u-joints on the drive shaft aren't loose.
Let me know what you find.
Jun 4, 2009 at 3:41 PM
LORENZOALVISE
...I ended up replacing the number 6 u-joint and the sensor on top of the rear axle that has to do with the rear brake anti lock. Fixed it right on up.
Jun 5, 2009 at 2:36 PM
  • 110,248 POSTS
I'm glad you got it fixed. If you have questions in the future, let us know.
Jun 5, 2009 at 4:11 PM
